Is it possible to belong to more than one ArcGIS Online organization while using the same user name?
It is your username that has to be different. In my case, I have two user names and belong to the same organization because I have different roles within there and different priviledges. More importantly, one of the names comes with me when I retire the other doesn't
well it is a good idea too... but you can have separate accounts and I would separate your esri account from a work account for sure check the docs in the workflow and design section What's new—ArcGIS Online Help | ArcGIS
Are you using a built-in username?
If so, i would think ArcGIS Online usually matches usernames to organizations based on its unique value when logging in. This is why: you can still login to www.arcgis.com using your built-in username and password and still login to the right organization. I am not sure if you would be able to use that same name in a different organization.
Aravind
Currently, one ArcGIS Online username can belong to one ArcGIS Online organization. One username cannot belong to two organizations. You can reuse your email address for many usernames.
-Kelly
