try it as a shapefile (precision 16, scale 😎 out of a gdb in a folder
000405 No records within table.DescriptionThere were no records available in the table on which to perform the operation. This warning can occur, obviously, when using an empty feature class or table, but it may also occur when working with a layer or table view containing an empty selection set. If a selection was applied against the layer or table view (for example, Select Layer By Location, Select Layer By Attribute) and it resulted in no records being selected, this warning will result.SolutionUse Get Count to return the number of available records or features within the input dataset. If the input is a layer or table view and there is a selection, it will return the number of selected records or features. Reexamine the query used to create the selection to ensure it is correct.
It seems that I have a global problem with some ArcToolbox instruments (ArcGIS10.0).I tried to use instruments "Add Xy Coordinate" and "Field Calculate". In both cases they doesn�??t work, the program gave zero (0) for all objects in all new fields.Really, I can�??t imagine the reason of it. What shall I try to do with that?
did you create double fields with an appropriate field and scale and precision?
