Here is the code to produce fishnet with a 0.0001 DD step
fishNetSymbol = new esri.symbol.SimpleLineSymbol().setColor(new dojo.Color("white"));
var FishNetLayer = new GraphicsLayer({ "id": nameLayer.fishNet });
FishNetLayer.on("visibility-change", function (evt) { if (map.getLevel() > 17 && evt.visible) showFishNetLayer(0.0001); });
var showFishNetLayer = function (precision) { var upperLeftPoint; var lowerRightPoint require([
"esri/geometry/webMercatorUtils", "dojo/dom", "dojo/domReady!"
], function ( webMercatorUtils, dom ) { upperLeftPoint = webMercatorUtils.xyToLngLat(map.extent.xmin, map.extent.ymax); lowerRightPoint = webMercatorUtils.xyToLngLat(map.extent.xmax, map.extent.ymin); });
var mapXMin = floor(upperLeftPoint[0], precision); var mapXMax = ceiling(lowerRightPoint[0], precision); var mapYMin = floor(lowerRightPoint[1], precision); var mapYMax = ceiling(upperLeftPoint[1], precision); showFishnet(mapXMin, mapYMax, mapXMax, mapYMin, precision); }
var showFishnet = function (mapXMin, mapYMax, mapXMax, mapYMin, precision) { mapXMin = parseFloat(mapXMin); mapYMax = parseFloat(mapYMax); mapXMax = parseFloat(mapXMax); mapYMin = parseFloat(mapYMin); precision = parseFloat(precision); require([ "esri/layers/GraphicsLayer", "esri/geometry/Polyline", "esri/graphic", "dojo/dom", "dojo/domReady!" ], function ( GraphicsLayer, Graphic, Polyline, domConstruct,dom ) { for (var x = mapXMin + precision / 2; x < mapXMax; x = x + precision) { var singlePathPolyline = new Polyline(); singlePathPolyline.addPath([[x, mapYMin], [x, mapYMax]]); var graphic = new esri.Graphic(singlePathPolyline, fishNetSymbol); map.getLayer(nameLayer.fishNet).add(graphic);
} for (var y = mapYMin + precision/2; y < mapYMax; y = y + precision) { var singlePathPolyline = new Polyline(); singlePathPolyline.addPath([[mapXMin, y], [mapXMax, y]]); var graphic = new esri.Graphic(singlePathPolyline, fishNetSymbol); map.getLayer(nameLayer.fishNet).add(graphic); } }); }
