All,ArcGIS Version: 10.1 SP1SQL SRVR Version: 2008 R2ArcSDE Version: 10.1 SP1 (x64)We have identified curious behavior with our plans table. It appears that our System Default Map Plan has switched with another plan. Another plan has appeared to have inherited the system default map plan parcels. The editor who created the plan mentioned having difficulty creating the plan. They may have renamed the default map plan from the plan directory. Is it possible rename the default map plan? If this is possible, I believe that renaming the default map plan means that the rename captured all of the parcels linked to the original. The new default map plan has 61 parcels in it so perhaps it was recreated? Any thoughts on what could be happening?See the output from a query of our SQL Server Database in the attached snapshots.
