protected function showMarker():void { const mapPoint:MapPoint = new MapPoint(-71.56, 45.33); const latlong:MapPoint = WebMercatorUtil.geographicToWebMercator(mapPoint) as MapPoint; var myGraphicMarker:Graphic = new Graphic(latlong, new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933)); myGraphicMarker.toolTip = "Marker added with ActionScript"; repeaterLayer.add(myGraphicMarker); myMap.centerAt(myGraphicMarker.geometry as MapPoint); }
const mapPoint:MapPoint = new MapPoint(-71.56,45.33); const latlong:MapPoint = WebMercatorUtil.geographicToWebMercator(mapPoint) as MapPoint;
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" width="100%" height="100%"> <!-- States --> <s:states> <s:State name="test"/> </s:states> <!-- WebServices, etc... --> <fx:Declarations> <!-- Place non-visual elements (e.g., services, value objects) here --> </fx:Declarations> <fx:Script> <![CDATA[ //Flex import mx.collections.ArrayCollection; import mx.controls.Alert; import mx.core.FlexGlobals; import mx.events.FlexEvent; import flash.sampler.NewObjectSample; import mx.rpc.events.ResultEvent; //ESRI Object import com.esri.ags.events.ExtentEvent; import com.esri.ags.geometry.Geometry; import com.esri.ags.geometry.MapPoint; import com.esri.ags.geometry.Extent; import com.esri.ags.Graphic; import com.esri.ags.layers.TiledMapServiceLayer; import com.esri.ags.layers.GraphicsLayer; import com.esri.ags.SpatialReference; import com.esri.ags.symbols.PictureMarkerSymbol; import com.esri.ags.utils.WebMercatorUtil; //***************************************** Affichage des repeteurs ********************************** protected function showMarker():void { var myGraphicMarker:Graphic = new Graphic(new MapPoint(-71.98, 45.33, new SpatialReference(4326)), new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND, 22, 0x009933)); myGraphicMarker.toolTip = "Marker added with ActionScript"; repeaterLayer.add(myGraphicMarker); myMap.centerAt(myGraphicMarker.geometry as MapPoint); } ]]> </fx:Script> <!-- Map --> <esri:Map id="myMap" level="4" load="myMap.centerAt(new MapPoint(-7133000, 4522000));" bottom="40" left="7" right="7" top="7"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <!-- Layer --> <esri:GraphicsLayer id="repeaterLayer"> <esri:Graphic> <esri:symbol> <esri:SimpleMarkerSymbol color="0x0033DD" size="18"/> </esri:symbol> </esri:Graphic> </esri:GraphicsLayer> </esri:Map> <s:Button label="CLICK ME" click="showMarker();" bottom="5" left="11"/> </s:Application>
var myGraphicMarker:Graphic = new Graphic(new MapPoint(1447100, 7477200, new SpatialReference(102100)),
