private void BitmapTest() { string sError = ""; try { string sURL = "http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer/export"; string sData = "?f=image"; int iWidth = (int)MyMap.Width; int iHeight = (int)MyMap.Height; sData += "&size=" + iWidth.ToString() + "," + iHeight.ToString(); sData += "&bbox=-121,32,-113,36"; Uri uri = new Uri(sURL + sData); HttpWebRequest req = (HttpWebRequest)WebRequest.Create(uri); req.BeginGetResponse(new AsyncCallback(RespCallback), req); } catch (WebException e) { sError = e.Message; } catch (Exception e) { sError = e.Message; } } private void RespCallback(IAsyncResult ar) { string sError = ""; try { HttpWebRequest req = (HttpWebRequest)ar.AsyncState; HttpWebResponse res = (HttpWebResponse)req.EndGetResponse(ar); if (res.StatusCode == HttpStatusCode.OK) { string sType = res.ContentType; int iLen = (int)res.ContentLength; Stream stream = res.GetResponseStream(); this.Dispatcher.BeginInvoke(() => StreamToBitmap(stream)); } } catch (WebException e) { sError = e.Message; } catch (Exception e) { sError = e.Message; } } private void StreamToBitmap(Stream s) { string sError = ""; try { BitmapImage bmi = new BitmapImage(); bmi.SetSource(s); WriteableBitmap wbm = new WriteableBitmap(bmi); int iWidth = wbm.PixelWidth; int iHeight = wbm.PixelHeight; int i = wbm.Pixels[0]; // Bingo! } catch (Exception e) { sError = e.Message; } }
Is there any way in REST/Silverlight to export a map to an image file? WriteableBitmap won't allow access to content from a UI element that uses URL-derived properties.
