We basically need to connect regions with the lowest z values, then those with the next lowest, etc, with interpolation between our points.
Ok, let me try again. We have about 20 of sites in Africa, each defined by lat, long and a third variable. Instead of elevation our 'z' variable is a measurement of the ecological distance between each site and an archaeological site. We want to display this visually by plotting contours on a map, but we aren't sure what interpolation method to use to plot the contours between the sites. One suggestion we have gotten is nearest neighbour, but I've also tried IDW and Global Polynomial. Does that help at all?
Kriging is more for parameter estimation than making contours
If kriging is the optimal interpolator (under certain conditions), wouldn't it also be the optimal method for making contour maps?
