In ArcMap it's fairly easy to move around a map while in a an edit session with a given tool active; just click on the pan tool, make your move, click back on the edit tool you were using and pick up were you left off. All I've found so far in Pro is to use the mouse wheel to zoom in or out; that leaves the selected edit tool. But if I'm at the desired scale and need to pan, how do I do that? Am I missing something obvious?
