Why does the attribute name fields change after performing an intersect?
Are you sure that when you tried to run the tool, your data was not joined to a dataset?
This causes the output field names to come out as: dataset_Fields
Which then gets truncated to dataset_
So one of your datasets in the join was called geocoding?
Thanks all. I basically uninstall/reinstall ESRI and somehow it worked. My IT team indicated that there was something going on with the malware. Thanks!
the files had the same field names, you can have this since you don't want to overwrite existing data, hence the field name change based upon a minimal intrusion name outcome
Oh how I wish I could; unfortunately this data has privileged information.
Could you zip the two files you're attempting to run this 'Intersect' process on and post them here?
Thanks Mitch Muskchamp, but selecting 'ONLY FID', deleted all the data in the attribute table.
Try unslecting 'ALL' from the 'JoinAttributes' field in the 'Interset' tool window. Instead, select 'ONLY_FID'.
Are you sure it is replacing the fields and not just inserting and pushing the original fields to the right?
Let me know what happens.
It's weird. This particular intersection has changed the name of the original fields altogether. Thanks for your time.
I'm using 10.0; it adds a few fields but leaves the originals intact. Sorry, can't comment on 10.3; you may have discovered an undocumented feature, aka bug....
I am using 10.3.
Attribute table BEFORE intersect:
Attribute table AFTER intersect:
Can you provide an example? What version ArcGIS are you using?
