<\/P>
Ik probeer door de water outage template<\/A> te gaan om onze watergegevens en traceerservice te publiceren. Maar nadat ik mijn gegevens aan de doellaag heb toegevoegd om een geometrisch netwerk te maken, verschijnt er een fout zoals in de bijlage. Heeft iemand hetzelfde probleem gehad? <\/P><\/BODY><\/HTML>
Lin,
I have some questions, what version and license do you have for ArcGIS Desktop? This tool requires 10.6.1 and a Standard or Advanced licenses. If you meet those requirements, then could you provide me with the input parameters you used?
Hi Gelisa, the version of my ArcGIS Pro is 2.2.4 and for ArcMAP is 10.5. I have already created a geometric network once by using this tool from water outage components. But I copied and pasted data to wrong target layer at that time. Now I have firehydrant, systemvalve, systemmeter, service connection, service valve, supply and main as input parameter. I also try to publish original sample data but it shows same error so I also wonder about whether it is tool problem.
It would be helpful to see what else is in the GP Dialog. Also, this PYT requires a folder for all the logic, ensure where the PYT is, that the folder structure looks like this:
