Operations Dashboard AddIn - License error
While debugging custom Feature Action AddIn for Operations Dashboard, this error message appears:
{"License error with ArcGISRuntime. Main license has expired."}
For detailed info I append the call stack log below.
My development machine is licensed with ArcGIS Runtime SDK Standard license.
Do anybody experience the same issue?
Thank you,
Matej
Call Stack:
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.Layer.OnInitializationFailed(System.EventArgs e) + 0x11f bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.Layer.Initialize() + 0xd8 bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.GroupLayerBase.AnonymousMethod__FabricatedMethod4() + 0x28 bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.GroupLayerBase.Initialize.AnonymousMethod__0(object a, System.EventArgs b) + 0x54 bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.Layer.OnInitialized(System.EventArgs e) + 0x5d bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.Layer.Initialize() + 0x83 bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.TiledLayer.Initialize() + 0x4b bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.ArcGISTiledMapServiceLayer.AnonymousMethod__FabricatedMethod2b() + 0x28 bytes
ESRI.ArcGIS.Client.dll!ESRI.ArcGIS.Client.ArcGISTiledMapServiceLayer.MapServiceInfoInitialized.AnonymousMethod__30() + 0x1f4a bytes
WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) + 0x17c bytes
WindowsBase.dll!MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(object source, System.Delegate method, object args, int numArgs, System.Delegate catchHandler) + 0x47 bytes
WindowsBase.dll!System.Windows.Threading.DispatcherOperation.InvokeImpl() + 0x281 bytes
mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) + 0x285 bytes
mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) + 0x9 bytes
mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) + 0x57 bytes
WindowsBase.dll!System.Windows.Threading.DispatcherOperation.Invoke() + 0x71 bytes
WindowsBase.dll!System.Windows.Threading.Dispatcher.ProcessQueue() + 0x2a1 bytes
WindowsBase.dll!System.Windows.Threading.Dispatcher.WndProcHook(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) + 0xb3 bytes
WindowsBase.dll!MS.Win32.HwndWrapper.WndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam, ref bool handled) + 0x14a bytes
WindowsBase.dll!MS.Win32.HwndSubclass.DispatcherCallbackOperation(object o) + 0x80 bytes
WindowsBase.dll!System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate callback, object args, int numArgs) + 0x5e bytes
WindowsBase.dll!System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority priority, System.TimeSpan timeout, System.Delegate method, object args, int numArgs) + 0x2bc bytes
WindowsBase.dll!MS.Win32.HwndSubclass.SubclassWndProc(System.IntPtr hwnd, int msg, System.IntPtr wParam, System.IntPtr lParam) + 0x140 bytes
[Native to Managed Transition]
[Managed to Native Transition]
WindowsBase.dll!System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame frame) + 0x112 bytes
PresentationFramework.dll!System.Windows.Application.RunInternal(System.Windows.Window window) + 0x17a bytes
PresentationFramework.dll!System.Windows.Application.Run() + 0x67 bytes
OperationsDashboard.exe!ESRI.ArcGIS.OperationsDashboard.Internal.App.Main() + 0x76 bytes
