I am working with ArcGIS Server 10.5 and my problem is a double relationship between my data (web portal).
I have a layer (point) with different fields. Two fields is used to create two relations on a table (analysis) :
I have a table (analysis) with two fields to make two relations on an entity layer
I create two relationships between these data: Analysis 0 to P 0 and Analysis 1 to P 1.
I publish the data as a Map service. When I select an entity, I can see the results of these relationships by "show related records".
But when I try to configure popup to get these results, only the first relation is displayed; for the second nothing is returned.
I'm searching for a solution to add the second relation in a popup.
