Public Sub SelectDanglingPolylines() ' Description: Takes a polyline dataset and select all dangling polylines. ' ' Requirements: You need to be in edit mode and have added the layer to a MAP TOPOLOGY, ' also polyline layer must be first in TOC. ' ' Limitations: Large datasets take a long time to build the cache and may even fail. ' ' Author: Duncan Hornby ' Created: 11/12/2011 ' ' Get map and then first layer, must be of polyline type Dim pMXDocument As IMxDocument Set pMXDocument = ThisDocument Dim pMap As IMap Set pMap = pMXDocument.FocusMap Dim pLayer As ILayer Set pLayer = pMap.Layer(0) Dim pFeatureLayer As IFeatureLayer Set pFeatureLayer = pLayer Dim pFeatureClass As IFeatureClass Set pFeatureClass = pFeatureLayer.FeatureClass If pFeatureClass.ShapeType <> esriGeometryPolyline Then MsgBox "This code works only with polylines!", vbExclamation, "Wrong data type at layer 0" Exit Sub End If ' Get editor and topology extension Dim pEditor As IEditor Dim pID As New UID Dim pTopologyExtension As ITopologyExtension Dim pTEID As New UID pID = "esriEditor.editor" Set pEditor = Application.FindExtensionByCLSID(pID) pTEID = "esriEditorExt.TopologyExtension" Set pTopologyExtension = Application.FindExtensionByCLSID(pTEID) If pTopologyExtension.CurrentTopology Is Nothing Then Exit Sub ' Get a MAP topology not a geodatabase topology Dim pMapTopology As IMapTopology If TypeOf pTopologyExtension.CurrentTopology Is IMapTopology Then Set pMapTopology = pTopologyExtension.MapTopology Else ' Not a Map Topology Exit Sub End If ' This is the colection that FID are added to Dim aColl As New Collection ' Build cache Application.StatusBar.Message(0) = "Building MAP TOPOLOGY cache, this can take a long time on large datasets..." DoEvents Dim pGeoDataset As IGeoDataset Set pGeoDataset = pFeatureClass Dim pEnvelope As IEnvelope Set pEnvelope = pGeoDataset.Extent pMapTopology.Cache.Build pEnvelope, False ' Identify dangling nodes and add polyline FID to collection Application.StatusBar.Message(0) = "Identifying dangling nodes..." DoEvents Dim pEnumTopologyParent As IEnumTopologyParent Dim pTopologyNode As ITopologyNode Dim pEnumTopologyNode As IEnumTopologyNode Set pEnumTopologyNode = pMapTopology.Cache.Nodes pEnumTopologyNode.Reset Set pTopologyNode = pEnumTopologyNode.Next While Not pTopologyNode Is Nothing If pTopologyNode.Degree = 1 Then ' As this has 1 degree it has only 1 parent polyline Set pEnumTopologyParent = pTopologyNode.Parents pEnumTopologyParent.Reset aColl.Add (pEnumTopologyParent.Next.m_FID) 'Adds polyline FID to collection End If Set pTopologyNode = pEnumTopologyNode.Next Wend ' Use collection to select polylines Application.StatusBar.Message(0) = "Selecting polylines..." DoEvents Dim pFeatureSelection As IFeatureSelection Set pFeatureSelection = pFeatureLayer Dim X As Variant For Each X In aColl pFeatureSelection.SelectionSet.Add CLng(X) Next pMXDocument.ActiveView.PartialRefresh esriViewGeoSelection, Nothing, pEnvelope Application.StatusBar.Message(0) = "" DoEvents End Sub
