import arcpy, sys, string, os, ArcHydroToolsarcpy.CheckOutExtension("Spatial")arcpy.env.overwriteOutput = True arcpy.env.workspace = "C:/Temp/" #arcpy.GetParameterAsText(0)class myArcHydro: def myInputDESC(inputDEM): desc = arcpy.Describe(inputDEM) print desc.format if desc.format != 'GRID': arcpy.ASCIIToRaster_conversion(inputDEM, outputDEM, "FLOAT") def projCheck(): dataSpatRef = arcpy.Describe(inputDEM).spatialReference if dataSpatRef.Type != "Projected": arcpy.AddError("Error: " + inputDEM + " must have a projected coordinate system") def myArcHydroTools(inputDEM, outputSHP, outputDIR): # Check out any necessary licenses and toolboxes arcpy.CheckOutExtension("spatial") #ArcHydroTools.AssignHydroID(tmpPolyFC, "OVERWRITE_YES") for dem in inputDEM: # Output Filenames Fil = outputDIR + "/fil" Fdr = outputDIR + "/fdr" Fac = outputDIR + "/fac" Str = outputDIR + "/str" StrLnk = outputDIR + "/strlnk" Cat = outputDIR + "/cat" Catchment = outputDIR + "/Catchment" DrainageLine = outputDIR + "/DrainageLine" AdjointCatchment = outputDIR + "/AdjointCatchment" DrainagePoint = outputDIR + "/DrainagePoint" # Run processes try: ArcHydroTools.FillSinks(inputDEM, Fil) ArcHydroTools.FlowDirection(Fil, Fdr) ArcHydroTools.FlowAccumulation(Fdr, Fac) ArcHydroTools.StreamDefinition(Fac, "", Str) ArcHydroTools.StreamSegmentation(Str, Fdr, StrLnk) ArcHydroTools.DrainageLineProcessing(StrLnk, Fdr, DrainageLine) ArcHydroTools.CatchmentGridDelineation(Fdr, StrLnk, Cat) ArcHydroTools.CatchmentPolyProcessing(Cat, Catchment) ArcHydroTools.AdjointCatchment(DrainageLine, Catchment, AdjointCatchment) ArcHydroTools.DrainagePointProcessing(Fac, Cat, Catchment, DrainagePoint) except: arcpy.AddWarning("ERROR. An error has occurred during processing.")if __name__ == '__main__': inputFile = arcpy.GetParameterAsText(0) outputFile = arcpy.GetParameterAsText(1) outputDIR = arcpy.GetParameterAsText(2) # Call the myArcHydroTools function. myArcHydroTools(inputFile, outputFile, outputDIR) print "success"
