[ATTACH=CONFIG]25357[/ATTACH]Hi Jason,Thanks for your advice! I tried to export a .dbf and it seemed to work, but I don't understand this flat minimum bounding rectangle problem...Qin
Qin Lin,I would suggest by passing the Excel table format. Try a test that consists of adding the Excel table to ArcMap with Add Data and then opening the table and selecting to export the table in dbase format (errors on import/export points towards a compatibility issue with the Excel file). Then try using this dbase version and see if it gives you any trouble.Regards,Jason R.
[ATTACH=CONFIG]25330[/ATTACH]I tried to do the integration before hot spot analysis.However this general error was persistent. the "sheet$1 events" layer is the imported xy coordinate from Excel.The "ExportRE" is the shape file of the xy coordinate.I used this shape file as the input in integrate.Can anyone help me point out the problem?Many thanks!
