I sincerely thanks your help with my question and had solved my problem.
This forum is lucky to have a person like yourself.
tags. //Declare this at the global scope var myGlobalVariable; function countfeat(type,select) { var selectedOption=select.options[select.selectedIndex]; query = new esri.tasks.Query(); query.where = type + " Like '%" + selectedOption.value + "%'"; queryTask = new esri.tasks.QueryTask("http://vdid-gisedn-2:8399/arcgis/rest/services/flow_BRID/MapServer/0"); queryTask.executeForCount(query, function(count){ alert(count); //it works here with a correct number returned //Yes, and this is where you assign the value to your variable, but you can only use the value AFTER this has been done alert("myGlobalVariable = " + myGlobalVariable); //Will have a value of undefined the first time this runs, thereafter will have the previous value...unless you clear it between calls myGlobalVariable = count; alert("myGlobalVariable = " + myGlobalVariable); //Will now have the value of count }); }; //Hook this function up to a button, it will allow you to check the value of the global variable function testValue(){ alert("myGlobalVariable = " + myGlobalVariable); //This will show undefined until the callback of executeForCount has run }
console.log("Declaring variable 'number'"); var number; //global variable declared console.log("Value of number = " + number); function countfeat(type,select) { console.log("countfeat called, number = " + number); var selectedOption=select.options[select.selectedIndex]; query = new esri.tasks.Query(); query.where = type + " Like '%" + selectedOption.value + "%'"; queryTask = new esri.tasks.QueryTask("http://vdid-gisedn-2:8399/arcgis/rest/services/flow_BRID/MapServer/0"); console.log("Before executeForCount, number = " + number); queryTask.executeForCount(query, function(count){ console.log("executeForCount callback called with count = " + count + ", number = " + number); number = count; //assign it to the global variable console.log("Finished executeForCount callback, value of number is now = " + number); }); console.log("After calling executeForCount, number = " + number); console.log("countfeat finished, number = " + number); }; //If you've just this code written in the global scope then it will execute immediately, definitely before you've even called your method above! if (number > 0){ alert(number); }
