I am having the same issue, when trying to use the Match Option CLOSEST in model builder arcmap crashes. On its own Spatial join preforms as expected. any help would be appreciated.JOIN_ONE_TO_ONEKeep All target Features: TrueI have sp3 installed.
Here is some sample data and a model that crashes when using spatial join. Windows 7. SP 3
Thanks for getting back with your tests (though bad π ). By "works in ArcGIS Desktop" you mean when you use the tool dialog, right?What is meant by 'fails miserably'? Does it crash when you use the tool in ModelBuilder? You are going to 'load full Service Pack' - which service pack? You need to have 10 sp4 installed and then install the patch on top of sp4. If you have sp3 then you don't need the patch. Please let us know if you are getting error on sp3.Thanks again.
