getpass works fine for standalone scripts but it seems it lock everything up if I use it in a script that is run from in ArcMap (10.0).I guess that it is still waiting for input that will never arrive.I presume that this is for a similar reason to print statements not working in this environment.There is an parameter type for scripts (ArcGIS 10.0) called "Encrypted String" which does mask on input but I am not sure what you can do with it in the script.I assume that the original poster wanted to then pass on the parameter to something else or compare it to known values as would I.
import subprocess def promptForPassword(): pwd=promptInNewProcess() pwd2=promptInNewProcess("Verify the new password: ") return pwd,pwd2 def promptInNewProcess(prompt="Enter a new password: "): cmd=r'python -c "from getpass import getpass; pwd=getpass(\"'+prompt+r'\"); print pwd"' p = subprocess.Popen(cmd, stdout=subprocess.PIPE) out, err = p.communicate() if (err==None): return out.strip() return ""
import arcpy from OraclePasswordFunctions import promptForPassword if __name__ == "__main__": if (len(sys.argv)<>2): print "There is 1 required input: " print " - SDE connection file to an ORACLE database (.sde). The user in the sde connection file is will be the user who's password gets changed" sys.exit(0) arcpy.AddMessage("\n\n\nThis utility will change the password of a SDE connection file. A command prompt will appear and ask for a new password. A second command prompt will then appear to validate the password (verify the inputs are the same). This utility uses the following criteria for password strength: ") arcpy.AddMessage(" - 8 or more characters in length") arcpy.AddMessage(" - 30 or less characters in length") arcpy.AddMessage(" - Start with an alpha character [a..z] or [A..Z]") arcpy.AddMessage(" - Contain at least 1 lower case character") arcpy.AddMessage(" - Contain at least 1 upper case character") arcpy.AddMessage(" - Contain at least 1 numeric character") arcpy.AddMessage(" - Contain at least 1 special character. The only special characters allowed are '_' or '#' or '$' (without quotes)") arcpy.AddMessage("\n\n\n") sde_ws = arcpy.GetParameterAsText(0) pwd1,pwd2=promptForPassword()
You can try using the getpass module for python.getpass
