package ee.alphagis.utils { public class SPUtils { /** * @param wkid Well-known ID * @return spatial reference <b>Well-known Text</b> by input Well-known ID, or <b>null</b> if not found */ public static function returnTextById(wkid:Number):String { var result:String = null; switch (wkid) { case 3819: { result = "GEOGCS[\"GCS_HD1909\",DATUM[\"D_Hungarian_Datum_1909\",SPHEROID[\"Bessel_1841\",6377397.155,299.1528128]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]]" break; } case 3821: { result = "GEOGCS[\"GCS_TWD_1967\",DATUM[\"D_TWD_1967\",SPHEROID[\"GRS_1967_Truncated\",6378160.0,298.25]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]]"; break; } //TODO: add needed cases here default: { break; } } return result; } /** * @param wkid Well-known ID * @return spatial reference <b>name</b> by input Well-known ID, or <b>null</b> if not found */ public static function returnNameById(wkid:Number):String { var result:String = null; switch (wkid) { case 3819: { result = "GCS_HD1909" break; } case 3821: { result = "GCS_TWD_1967"; break; } //TODO: add needed cases here default: { break; } } return result; } /** * @param wkid Well-known ID * @return spatial reference <b>Well-known Text</b> by input name, or <b>null</b> if not found */ public static function returnTextByName(name:String):String { var result:String = null; switch (name) { case "GCS_HD1909": { result = "GEOGCS[\"GCS_HD1909\",DATUM[\"D_Hungarian_Datum_1909\",SPHEROID[\"Bessel_1841\",6377397.155,299.1528128]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]]" break; } case "GCS_TWD_1967": { result = "GEOGCS[\"GCS_TWD_1967\",DATUM[\"D_TWD_1967\",SPHEROID[\"GRS_1967_Truncated\",6378160.0,298.25]],PRIMEM[\"Greenwich\",0.0],UNIT[\"Degree\",0.0174532925199433]]"; break; } //TODO: add needed cases here default: { break; } } return result; } } }
