Thanks for the log. A couple questions�?�1) In the setup, do you get to the panel that shows the license agreement? 2) Have you tried unblocking the exe? (right click, go to properties > General tab, click Unblock) If not, try it and see if you�??re able to run through the setup.3) Have you tried explicitly running the exe as an administrator? (right click, select �??Run as administrator�?�)4) Did you have ArcGIS Silverlight/WPF 1.x installed on this machine in the past? 5) What ESRI products do you have installed currently?Thanks
Can you generate another install log now that the vbscript.dll is registered? Send it to me via email at rhansen@esri.com Thanks
Any details you find that you can share will definitely help us to better understand and fix this problem.
Thanks Richard that would probably work if this was an msi.pat
