edit = getIWorkspaceEditUsingComtypes() #(this function returns IWorkspaceEdit successfully) edit.StartEditOperation ??? #(python code creating a feature using a Python Insert Cursor) edit.StopEditOperation
#ShieldToolComtypes_addin.py #KAlley 2013_11_11 #VT Agency of Transportation # #Based on ShieldTool_addin.py (KAlley 2013-03-12) #In this script, lines of code relevent to using arcpy.da.Editor are commented out import arcpy, time, os, sys, math sys.path.append("V:\Projects\Shared\kalley\PythonScripts") import comtypes, Snippets import pythonaddins class SelectRoadArcClass(object): """Implementation for TwoInputsAddin_addin_B.tool (Tool)""" def __init__(self): self.enabled = True self.shape = "NONE" # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks. def onMouseDownMap(self, x, y, button, shift): #start_time = time.time() #only used to compare run-times of different versions of the script arcpy.env.overwriteOutput = True path = r'V:\Projects\Shared\kalley\ToolDevelopment\ShieldToolComtypes\Install' print "Comtypes Version of the Shield Tool AddIn" #rdsmall_dataSource = r"GDB_HMS.HMSADMIN.rdsmall_arc" rdsmall_dataSource = r"GDB_HMSDev.HMSADMIN.rdsmall_arc_kalley" mxd = arcpy.mapping.MapDocument('current') for lyr in arcpy.mapping.ListLayers(mxd): if lyr.supports("dataSource"): if str(lyr.dataSource).endswith(rdsmall_dataSource): rdsmall_lyr = lyr point = arcpy.Point() point.X = x point.Y = y pointGeometry = arcpy.PointGeometry(point) arcpy.SelectLayerByLocation_management(rdsmall_lyr, "WITHIN_A_DISTANCE", pointGeometry, "40 Meters", "NEW_SELECTION") #print time.time() - start_time, "seconds" class CreateShieldClass(object): """Implementation for TwoInputsAddin_addin_A.tool (Tool)""" def __init__(self): self.enabled = True self.cursor = 3 self.shape = "LINE" # Can set to "Line", "Circle" or "Rectangle" for interactive shape drawing and to activate the onLine/Polygon/Circle event sinks. def onLine(self, line_geometry): start_time = time.time() #only used to compare rough run-times of different versions of the script arcpy.env.overwriteOutput = True #Hard-wiring the exact feature classes that will be edited with shield tool: ##VTrans Data: ##shield_points_dataSource = r"GDB_HMS.HMSADMIN.hms_shields_points" ##shield_arcs_dataSource = r"GDB_HMS.HMSADMIN.hms_shields_arcs" ##rdsmall_dataSource = r"GDB_HMS.HMSADMIN.rdsmall_arc" #Development Sandbox copy of VTrans data: shield_points_dataSource = r"GDB_HMSDev.HMSADMIN.hms_shields_points_kalley" shield_arcs_dataSource = r"GDB_HMSDev.HMSADMIN.hms_shields_arcs_kalley" rdsmall_dataSource = r"GDB_HMSDev.HMSADMIN.rdsmall_arc_kalley" #mxd = arcpy.mapping.MapDocument(r"K:\ToolDevelopment\ToolDevelopmentSDE.mxd") #for testing script independently of add-in mxd = arcpy.mapping.MapDocument('current') #for new shields to appear in current mxd, this script must refer to layers in the current mxd lyrs = arcpy.mapping.ListLayers(mxd) for lyr in arcpy.mapping.ListLayers(mxd): if lyr.supports("dataSource"): if str(lyr.dataSource).endswith(shield_points_dataSource): shield_points_lyr = lyr if str(lyr.dataSource).endswith(shield_arcs_dataSource): shield_arcs_lyr = lyr if str(lyr.dataSource).endswith(rdsmall_dataSource): rdsmall_lyr = lyr if not (shield_points_lyr and shield_arcs_lyr and rdsmall_lyr): print "Shield Not Created..." print "Must have at least 3 layers in this mxd: shield points, shield arcs, and rdsmall" #only allow shield creation if a single road arc is selected num_road_arcs = int(arcpy.GetCount_management(rdsmall_lyr).getOutput(0)) if num_road_arcs == 1: ##Code used if using arcpy.da.Editor ##workspace = rdsmall_lyr.workspacePath #for .gdb *and* SDE connection (refers to .sde file in DatabaseConnections) ##arcpy.env.workspace = workspace ##edit_py = arcpy.da.Editor(workspace) ##edit_py.startEditing() #with undo, multiuser mode #Code used if accessing preexisting editing session with comtypes/ArcObjects edit = Snippets.ArcMap_GetIWorkspaceEdit(bStandalone=False) if edit is None: print "Must be in an editing session to use this tool" return #identify maximum SHI_GRP_ID value currently used in shields max_id = sorted(arcpy.da.SearchCursor(shield_points_lyr.dataSource, "SHI_GRP_ID"), reverse = 1)[0][0] #collect selected road arc attributes rdsmall_values = sorted(arcpy.da.SearchCursor(rdsmall_lyr, ["UA", "FAID_S", "CTCODE", "RTNUMBER", "AOTCLASS"])) #initialize the new line as the input line_geometry (will change if fix_length == True) new_line = line_geometry #create shield point and populate attributes new_points_Cur = arcpy.da.InsertCursor(shield_points_lyr, ["SHAPE@XY", "UA", "FAID_S", "CTCODE", "RTNO", "AOTCLASS", "SHI_GRP_ID", "ISVISIBLE", "SUBINSET"]) test = (new_line.firstPoint,) + tuple(rdsmall_values) + (max_id + 1,) test_tuple = ((test[0].X, test[0].Y), test[1][0], test[1][1], str(test[1][2]), str(test[1][3]), test[1][4], test[2], 1, "N") ##edit_py.startOperation() edit.StartEditOperation new_points_Cur.insertRow(test_tuple) ##edit_py.startOperation() edit.StopEditOperation del new_points_Cur #create shield arc and populate SHI_GRP_ID new_arc_Cur = arcpy.da.InsertCursor(shield_arcs_lyr.dataSource, ["SHAPE@", "SHI_GRP_ID"]) ##edit_py.startOperation() edit.StartEditOperation new_arc_Cur.insertRow([new_line, max_id + 1]) ##edit_py.stopOperation() edit.StopEditOperation del new_arc_Cur ##edit_py.stopEditing(True) #save changes arcpy.SelectLayerByAttribute_management(rdsmall_lyr, "CLEAR_SELECTION") arcpy.RefreshActiveView() else: print "Shield Not Created..." print "Must select a single arc from rdsmall" #print time.time() - start_time, "seconds"
def ArcMap_GetIWorkspaceEdit(bStandalone=False): GetDesktopModules() if bStandalone: InitStandalone() pApp = GetApp() else: pApp = GetCurrentApp() GetModule("esriEditor.olb") import comtypes.gen.esriSystem as esriSystem import comtypes.gen.esriEditor as esriEditor import comtypes.gen.esriGeoDatabase as esriGeoDatabase pID = NewObj(esriSystem.UID, esriSystem.IUID) pID.Value = CLSID(esriEditor.Editor) pExt = pApp.FindExtensionByCLSID(pID) pEditor = CType(pExt, esriEditor.IEditor) if pEditor.EditState == esriEditor.esriStateEditing: pWS = pEditor.EditWorkspace pWSE = CType(pWS, esriGeoDatabase.IWorkspaceEdit) pDS = CType(pWS, esriGeoDatabase.IDataset) print "Workspace name: " + pDS.BrowseName print "Workspace category: " + pDS.Category return pWSE return
