I am wondering if this is possible because every time I change the alias of the GlobalID field and then remove the layer and re-add it to the map, the field becomes GloablID again. Is there really no way to save it? GlobalID is just so non-descriptive when you're trying to use it in related tables. It doesn't make it obvious that GlobalID is the _NameHere_ID in the other feature class.
