hi i am trying to add graphic to graphicslayer. here is the problem.
i get json result from sketchviewmodel create function which is graphic.
i store this in to new jsonobject. then i try to add this graphic into graphicslayer manually. but its giving error.
here is the json
{ "geometry":{ "spatialReference":{ "latestWkid":3857, "wkid":102100 }, "x":243208.09643883476, "y":2940285.766420703, "z":351.9580905416081 }, "symbol":{ "type":"point-3d", "symbolLayers":[ { "type":"Icon", "material":{ }, "resource":{ "primitive":"kite" }, "size":15, "outline":{ "color":[ 0, 0, 0 ], "size":2.25 } } ] }, "attributes":{ }, "popupTemplate":null }this code gives error
const [Graphic] = await loadModules(["esri/Graphic"]); let g = new Graphic(data); // data which is json i gave.
any adivce ? Thank you.
