it did work, which somehow it really is a odd or strange behaviour, as i said in my first post, the code worked liked a charm until yesterday morning
the portal object should have (i guess) the CurrentUser set, a Token etc.... and instead those values are always null. If i make a POST request to generateToken to require a token, and set the portal instance Token property with the returned value, CurrentUser property is always null.
using System.Windows; using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Portal; using Microsoft.Phone.Controls; namespace PhoneApp1 { public partial class MainPage : PhoneApplicationPage { public MainPage() { InitializeComponent(); IdentityManager.Current.TokenGenerationReferer = "file:///Applications/Install/"; IdentityManager.Current.GenerateCredentialAsync("http://www.arcgis.com/sharing/rest", "<username>", "<password>", (crd, err) => { if (crd != null) { var portal = new ArcGISPortal { Token = crd.Token }; portal.InitializeAsync(null, (p, e) => MessageBox.Show(p.CurrentUser.FullName)); } else MessageBox.Show("Error " + err.Message); }); } } }
If you are using using IE, that should work.For example, you can try to generate a token for the referer=http://<yourserver>
The problem was I changed "requestip" to my actual ip address.
My assumption is that token generated this way is bound to the ip and won't work if the map request is sent from a different IP?
Do you have any theory why the token generated using referer=MyToken won't work?
Yes:{"error":{"code":400,"message":"Unable to generate token.","details":["Invalid username or password."]}}
Strange! You got an error as if the option client=requestid was missing.Do you get that error when clicking on this link : https://www.arcgis.com/sharing/generateToken?f=json&username=myusername&password=mypassword&client=requestip
I did try what you suggested (space added so the full string can be shown):h t t ps://www.arcgis.com/sharing/generateToken?f=json&username=myusername&password=mypassword&client=requestipbut got an effor message:{"error":{"code":400,"message":"Unable to generate token.","details":["'referer' must be specified."]}}
Might be a problem due to the referer (I am not sure which referer you set in your token request).Instead of generating a token associated to a referer, you can try to generate a token associated to your ip address.Something like:https://www.arcgis.com/sharing/generateToken?f=json&username=myusername&password=mypassword&client=requestip
