As for the black/white checkerboard, this indicates the imagery could not be found by the server.
Basically imagery is on server B and ArcGIS Server is on server A. I've registered a shared folder on server B that has the imagery in it and also added an arcgis user and gave it read permissions to the imagery. I can successfully view the mosaic dataset when logged in as me and also the arcgi user, but when I publish it to ArcGIS Server and view the service (as a map service or imagery service) I got the checkered tiles below around 1:5000, so yeah the overviews are readable, but for some reason ArcGIS Server is not reading the imagery even though I've setup all the correct permissions etc.?
Having an issue when I publish a mosaic dataset map service to server. When I zoom in past 1:2000, the imagery disappears and black and white check background shows? When I zoom in past 1:2000 in the actual mosaic dataset it works fine, just when viewing it in a map service, it won't show the imagery past 1:2000 (either cached or dynamic), see map service here:http://203.190.214.166/arcgis/rest/services/Masterton/Imagery/MapServer?f=jsapi
Did this ever get resolved? I am having the same issue. It works on my 10.2 arc gis server but not my 10.2.1 arcgis server.
F&^%$^&ing ArcGIS - it's taken me a week and a half of frustration to only find out that its the ECW files I'm using that are the issue! Not to mention the file paths, the options that aren't options, the need to manually specify MaxPS values, to boost the rows and columns numbers...why does it have to be so F%#$$%% hard to load rasters into a dataset and have them display?????
ArcGIS Server service account should have access to imagery.
