Since you said that numbers worked, you mean that numbers for the EVENT field worked? If so, are you using domains or subtypes? Maybe you need to call the coded value/number rather than the description? Like if RED FLAG WARNING was coded as a number nine, then you'd type in EVENT = 9 or even EVENT = '9' ? I realized afterwards that this is the ArcGIS Online section... Not sure if my response would help at all.
I'm trying to create a query on the US Weather Warnings Service in ArcGIS Explorer Online to locate types of EVENTS (really, I'm just testing the query function). So I click the Query Button, select the layer and construct my query:EVENT = 'RED FLAG WARNING'Seems pretty simple, but I get an error - Unable to perform query. Check the syntax and try again.I've tried single quotes, double quotes, no quotes. And I've tried queries on different services. If I query for a number I get results, but not if I query text. Any ideas?Sue
