print "the input list" for f in fcs: print f
import sys, string, os, win32com.client gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
import sys, string, os, arcgisscripting gp = arcgisscripting.create()
#BatchClipFCs.py # #Author # Dan Patterson # Dept of Geography and Environmental Studies # Carleton University, Ottawa, Canada # Dan_Patterson@carleton.ca # #Purpose # Batch clips feature classes (eg shapefiles) in a project # and writes them to a folder. # Many batch clip examples exist, this is compiled for demonstration # purpose for a class # #Properties (right-click on the tool and specify the following) #General # Name BatchClipFCs # Label Batch Clip Feature Classes # Desc Batch clip feature classes (eg shapefiles) and saves # them to a folder. # #Source BatchClipFCs.py # #Parameter list # Parameter Properties # Display Name Data type Type Direction MultiValue # argv[1] Feature(s) to clip Feature Layer Required Input Yes # argv[2] Polygon clip layer Feature Layer Required Input No # argv[3] Append to output String Optional Input No # filename # argv[4] Output folder Folder Required Input No #-------------------------------------------------------------------- #Import the standard modules # Get a list of feature classes (shapefiles) # Get the clip feature class # Get the optional text to append to the filename output filename # Get the output folder # Usage: BatchClipFCs <Input_Features> <ClipWith> <optional_text> <Output_Workspace> # --------------------------------------------------------------------------- # # Import system modules, Create the Geoprocessor object and # Load required toolboxes... # import sys, string, os, arcpy # # Script arguments... FCsToClip = arcpy.GetParameterAsText(0) #a list of features fcs = string.split(FCsToClip, ";") #split into a list # clipWith = arcpy.GetParameterAsText(1) #clip layer desc = arcpy.Describe(clipWith) clipWithType = desc.ShapeType # addToName = arcpy.GetParameterAsText(2) #optional text to append to output name if(addToName == "#"): addToName = "" # outputFolder = arcpy.GetParameterAsText(3) #a folder # arcpy.AddMessage("\n" + "Batch Clip Feature layers" + "\n" ) # if (clipWithType == "Polygon"): for fc in fcs: try: fc=fc.replace("'","") #check if a layers name has been changed desc = arcpy.Describe(fc) fcDataType = desc.DataType arcpy.AddMessage("Data type = " + fcDataType) if(fcDataType == "FeatureClass"): # Feature class on disk theName = str(os.path.split(fc)[1]) outFile = outputFolder + "\\" + theName + addToName + ".shp" else: # Feature layer FullName = desc.CatalogPath theName = (os.path.split(FullName)[1]).replace(".shp","") theName = str(fc).replace(" ","_") outFile = outputFolder + "\\" + theName + addToName + ".shp" arcpy.AddMessage("Output file from layer " + outFile) # arcpy.AddMessage("Clipping " + str(fcDataType) + ": " + fc + " Saving to: " + outFile + "\n") try: arcpy.Clip_analysis(fc, clipWith, outFile, "") except: arcpy.AddMessage("Could not clip " + fc + " with " + clipWith + " to " + outFile) except: arcpy.AddMessage("cannot describe" + fc) else: arcpy.AddMessage (clipWith + " is not a polygon layer, clipping terminated" ) #
