I hope the Mosaic allow for this.
Hi Eric, thanks for the info. I was able to create a new raster catalog and mosaic dataset with New > Raster Catalog... and New > Mosaic Dataset but I don't see how to load my existing raster catalog into either. All load/import tools are looking for datasets or raw images.
Greetings,All you need to do is build a new raster catalog with the coordinate system you want. Specifically, you want to look at the "Coordinate System for Raster Column" parameter. The spatial reference of the raster column is used during data loading as:A default spatial reference for those raster datasets that have an unknown spatial referenceA target spatial reference if you choose to project your raster datasets that have different spatial references from the raster columnThe raster catalog has been superseded by the mosaic dataset, which has many more capabilities, uses, and functions. Therefore, it is recommended that you manage raster data using a mosaic dataset instead of using a raster catalog. Mosaic datasets can be in a different coordinate system (and even datum- unlike catalogs) than the source data feeding into it.Best,Eric
