Hi Gustavo.I tried the same script and ran into similar problems as you did. I used the line format you provide and was able to get it to work.I couldn't figure out why the original line worked on the sample script but not on mine. I did run into another problem and I'm curious to know if you also had a similar problem. Once I ported the ArcPad project to my trimble unit I called up the apm and the form entry box poped up as expected. But I could not fill in the popup form entry box because I couldn't get the keyborad to come up until the form entry box cleared from the screen. Does it behave this way with your gps unit. I have a trimble juno sb with arcpad10.0
Still can't understand why It didn't work, but I have solved the problem!I have just changed my objectThisEvent.Object.Controls("txtIDTABLET").TextwithLayer.Forms("EDITFORM").Pages("page1").Controls("txtIDTABLET").Textand it worked!!!Hope it helps someone else...Gustavo
