Have you been able to repro the crash on any other Android devices?For the sync failures can you enable debug logging on the server and send me the logs when you try to sync a feature?ThanksRuss
1) Can check to make sure in the GDB that attachments are configured properly (globalids + NV archiving)2) Are you seeing this error every time time they sync where the upload an attachment? If so, can they send the debug server logs?3) What DBMS are they using? What is the release info (GDB release, sever release �?? all 10.2.2?)ThanksRuss
Also are you using server 10.2.2 ? ThanksRuss
This morning I setup all new feature classes with all the appropriate settings (global ID's, none versioned archiving, attachments, editor tracking). I created an MXD, published the MXD with feature access (with sync enabled). Created a map in AGOL, added the feature service, shared the map, enabled offline mode. Pulled the map up on Collector. Downloaded the map. Added a point feature with picture attachment. Synced the map. Error syncing. Same error as above. The test point feature did make it back to our database but the sync won't complete on the device without throwing that error. Not sure what else I can try or do.
