an anyone explain how to calculate xy in degrees minutes seconds in the attribute table?
You could use Convert Coordinate Notation—Help | ArcGIS Desktop
For output_coordinate_format, choose any one of the following (DMS_2 is preferable).
Thanks for the tip, I did try that but it is not calculating any values. All attributes are null.
Is there any python that will calculate this in an existing feature class? I don't like that the convert coordinate notation creates a new FC
Here you go How To: Convert Decimal Degree values to Degree Minute Seconds values using the Field Calculator
Did you consider using Calculate Geometry for calculating the XY values in DD? Calculating area, length, and other geometric properties—Help | ArcGIS Desktop
In my earlier responses I have assumed that you don't need XY values in DD, but only in DMS.
Another similar thread (Resolved) https://community.esri.com/thread/27279
Yes, but I need to do this in Pro not Desktop.
Oh. I didn't realize that. In ArcGIS Pro you could use Add Geometry Attributes—Data Management toolbox | ArcGIS Desktop
Thanks but I tried that too. You don't have the ability to change format in that tool, the XY output is in northing and easting.
