Hi All,
I want to know if map extent and screen size are related.
My observation:
I have developed a JavaScript web application. This application has side panel. When panel opens I shift the map rather than adding a overlay. I have defined extent (WKID 102100)Â in application configuration file. When I run the application on iPad in landscape and portrait mode and click on the default extent (this is nothing but I read the extent from config file and call map.setExtent(extent_from_Config) ) i observe that map zooms out a little. Hence i think extent and scree size are related.
Please let me know if this is expected behavior. Also any material you can provide to clear related concept would be helpful
Regards,
Rahul
