If I display my layer based on specific attribute value, in the legend the name of the values are displayed as "Override1", "Override 2" and etc...
It started to happen after AGOL latest update.
In the web map, it is fine:
yes. That is a bug BUG-000094164.
Thank you!
Linana,
Sounds like a bug you need to report to esri technical support.
I tested with other layers and this issue happens whenever I display symbology based on the attribute that has STRING value.. If it is not text, it works fine.
Hi Adrian,
This is web app builder in AGOL, not developer edition.
Here is web map and the application:
http://mdc.maps.arcgis.com/home/webmap/viewer.html?webmap=d33d15a8b7974575b0ceecba1fc5e2db
ArcGIS Web Application
Hi Liana,
That is an odd issue. It may help to describe where you are seeing this legend change (I presume WAB, but which version? developer edition?) and when you saw it start happening. Plus, is there a way for you to share the web map and app?
https://community.esri.com/community/gis/web-gis/arcgisonline?sr=search&searchId=5cdebdcd-efd1-4c84-83ef-1d05eec32d84&searchIndex=1
