I am trying to load my data attribute table but I am getting the error (attached) that says an unexpected error occured. What could be causing this?
Great idea, Robert LeClair. In a similar vein, TKM ., you might have some luck solving the problem by checking the geometry for errors (more info on how to check and repair any errors you found here).
Export the data to a shapefile first - does the exported data say anything like "empty output"? If so, then the data is corrupted. If it does not say this, then reimport it back into your geodatabase. Any error message?
Kelly, I have no any joins in my data. I am wondering why this should be the case when I have done all those hacks with no any promising outcome.
I see this error occasionally when the attribute table I am trying to open has another table joined to it.
I am usually able to fix this by removing the join and creating it again. If that doesn't work, I've also had luck closing the project and opening it again.
