Public Function Clip(ByVal pInFClass As ESRI.ArcGIS.Geodatabase.IFeatureClass, ByVal pClipFClass As ESRI.ArcGIS.Geodatabase.IFeatureClass, ByVal OutputName As String) As ESRI.ArcGIS.Geodatabase.IFeatureClass Dim Clipper As New ESRI.ArcGIS.AnalysisTools.Clip Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Try Using releaser As New ESRI.ArcGIS.ADF.ComReleaser releaser.ManageLifetime(Clipper) Clipper.in_features = pInFClass Clipper.clip_features = pClipFClass Clipper.out_feature_class = OutputName Result = RunTool(Clipper, Nothing) If Result Is Nothing Then System.Windows.Forms.MessageBox.Show("Could not clip dataset") Return Nothing End If Return ReturnObjectfromResult(Result, "Feature Class") End Using Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Clip error") Return Nothing End Try End Function Private Sub ReturnMessages(ByVal pResult As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Title As String) Dim ErrorMessage As String If pResult.MessageCount > 0 Then For Count As Integer = 0 To pResult.MessageCount - 1 ErrorMessage += pResult.GetMessage(Count) Next End If System.Windows.Forms.MessageBox.Show(ErrorMessage, Title) End Sub Friend Function ReturnObjectfromResult(ByVal result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2, ByVal Type As String) As Object Dim GPVal As ESRI.ArcGIS.Geodatabase.IGPValue Dim InMemFC As String Dim GPUtil As ESRI.ArcGIS.Geoprocessing.IGPUtilities3 = New ESRI.ArcGIS.Geoprocessing.GPUtilities Try GPVal = result.GetOutput(0) InMemFC = GPVal.GetAsText() Select Case Type Case "Feature Class" Return GPUtil.OpenFeatureClassFromString(InMemFC) Case "Table" Return GPUtil.OpenTableFromString(InMemFC) End Select Catch ex As Exception System.Windows.Forms.MessageBox.Show(ex.ToString, "Return FeatureClass error") Return Nothing End Try End Function Friend Function RunTool(ByVal Process As ESRI.ArcGIS.Geoprocessor.IGPProcess, ByVal TC As ESRI.ArcGIS.esriSystem.ITrackCancel2) As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Dim Result As ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2 Try 'I am using a global variable for the Geoprocessor Result = CType(Globals.GP.Execute(Process, Nothing), ESRI.ArcGIS.Geoprocessing.IGeoProcessorResult2) If Result.Status <> ESRI.ArcGIS.esriSystem.esriJobStatus.esriJobSucceeded Then ReturnMessages(Result, "Geoprocessing Error") Globals.GP.ClearMessages() Catch ex As Exception ReturnMessages(Result, "Fail") System.Windows.Forms.MessageBox.Show(ex.ToString, "Run Geoprocessor") End Try Return Result End Function
All,I'm automating a process for some workmates involving 3 geoprocessing commands. I'm using ArcObjects C#. I'm having some difficulties getting the Intersect object to like what I'm passing it for in_features. Documentation is scarce and I can't find any examples. The input is of type object, which is horribly unhelpful, since if you pass it the apparently wrong type of object the thing just fails without any explanation. If someone has a .NET example of using ESRI.ArcGIS.AnalysisTools.Intersect please post your code. This repeated poke and hope approach is draining my time and patience.Many thanks.
