<esri:Legend Map="{Binding ElementName=MyMap}"[INDENT]LayerItemsMode="Tree"> <i:Interaction.Triggers>[/INDENT] [INDENT=2]<i:EventTrigger EventName="Refreshed" >[/INDENT] [INDENT=3]<Commands:InvokeCommandActionWithArgs Command="{Binding LegendRefreshedCommand}" />[/INDENT] [INDENT=2]</i:EventTrigger>[/INDENT] [INDENT]</i:Interaction.Triggers>[/INDENT] </esri:Legend>
public class InvokeCommandActionWithArgs : TriggerAction<DependencyObject> { public static DependencyProperty CommandProperty = DependencyProperty.Register("Command", typeof(ICommand), typeof(InvokeCommandActionWithArgs)); public ICommand Command { get { return GetValue(CommandProperty) as ICommand; } set { SetValue(CommandProperty, value); } } protected override void Invoke(object parameter) { if (Command == null) return; Command.Execute(parameter); } }
Mike,Thanks for your response. I considered handling the legend refreshed event, however I am using MVVM and that approach does not work well with the pattern. I may have a way to get around the MVVM issue, but it's not ideal. Do you have any suggestions on how to handle the event while maintaining strict adherence to MVVM (no code-behind)?Thanks,Cory
