import arcpy mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)[0] #Change the [number] to whichever dataframe you want to use (0 is the first dataframe, 1 in the second, etc.) rows = arcpy.SearchCursor(pointsLyr.dataSource) cols = arcpy.ListFields(pointsLyr.dataSource) for row in rows: for col in cols: if col.name == "LATITUDE": latstr = row.getValue(col.name) if col.name == "LONGITUDE": lonstr = row.getValue(col.name) if col.name == "OBJECTID": objstr = str(row.getValue(col.name)) arcpy.SelectLayerByAttribute_management(pointsLyr.dataSource,"NEW_SELECTION", ("%s = %s" % (col.name, objstr) newextent = df.extent xmin = float(lonstr) - .005 ymin = float(latstr) - .005 xmax = float(lonstr) + .005 ymax = float(latstr) + .005 newextent.XMin, newextent.YMin newextent.XMax newextent.YMax = xmin, ymin, xmax, ymax df.extent = newextent df.panToExtent(df.extent) arcpy.RefreshActiveView()
import arcpy mxd = arcpy.mapping.MapDocument("CURRENT") df = arcpy.mapping.ListDataFrames(mxd)[0] #Change the [number] to whichever dataframe you want to use (0 is the first dataframe, 1 in the second, etc.) for lyr in arcpy.mapping.ListLayers(mxd): if lyr.name=="Points": #Change to the name of the point layer in your table of contents pointsLyr=lyr break #this will only get the first occurance of the given name in the TOC rows = arcpy.SearchCursor(pointsLyr.dataSource) for row in rows: arcpy.SelectLayerByAttribute_management(pointsLyr, "NEW_SELECTION", '"FID" = '+str(row.FID)) df.zoomToSelectedFeatures() arcpy.SelectLayerByAttribute_management(pointsLyr, "CLEAR_SELECTION") #clears selected so that the exported PDF does not have that selected blue colouring df.scale=50000 #set scale as desired. If there is an attribute for scale use this: df.scale=row.Scale arcpy.RefreshActiveView() arcpy.RefreshTOC() arcpy.mapping.ExportToPDF(mxd, "C:\\Users\\jchishol\\Desktop\\TEMPzoompoint\\Output"+str(row.FID)+".pdf") #exports to PDFs. The files have the 'row.FID' in them so they do not all have the same name del mxd,df,lyr,pointsLyr,row,rows
