For windows XP the xml is located here:"C:\Documents and Settings\" & Environment.UserName & "\Local Settings\Application Data\ESRI\Desktop10.0\AddinFoldersList.xml"
Thanks guys. Although i havent been able to locate the AddinFoldersList.xml. I am using Windows XP. Any ideas where i can locate the file on XP.
Hi, I wanted to know if it was possible to programmatically add additional add-in folders (network path) in the Add-In Manager dialog box. Hence the end user doesn't need to do it. This should also enable the developer to provide later version of the add-in without need to re-send the new add-in file.Is this possible.Thanks
