Hi all,
Have had an issue lately with creating local copies of our organization's services to edit in ArcMap. We are using ArcGIS Enterprise 10.7.1 and we have a field team using Collector and Survey123. The layers in question are optimized for Offline use, with Sync and Editing enabled. Essentially every time I create a local copy for editing in ArcMap of a Feature Service, the geographic data copies correctly, but the photo attachments are missing
To sum up my workflow and issues I have:
- Add feature service from portal into ArcMap .mxd
- I am able to use the Identify tool to view photo attachments to the data
- Right click and create local copy of data to edit
- Creates local copy for a while, and then a Feature Class is copied to the FeatureServiceLocalEdits folder in a geodatabase alongside an (empty) attachment table and relationship class.
This presents a huge issue because if I were to republish and overwrite the original service with important edits that were made, critical attachments would be missing, and the originals removed.
Has anyone has any similar issues or has a solution/workaround? Is there something wrong with the configuration of my service? I have read elsewhere that attachments do not always copy correctly when editing and sync is enabled. I could disable those features but it would cause a disruption to our active field crew and the replicas of the service they may be using.
Many thanks
