Flex modules are not supported in Flex Mobile. This article ports the viewer to the desktop; the section which states:"The next step is to add all the modules to the project. Go to Project - Properties and then in the ArcGISFlexDesktop Properties dialog select Flex Modules and add the following mandatory widgets .... "is where you will fail when you try to set this up for use on iOS/Android in a Flex Mobile Project.--Rory
