or should I say to find a good best practice a guideline that I'm looking for a checklist sheet to reduce errors on map or data ? They can be from ESRI, or anywhere where I can read about them.
Everything will be an option
Dr Google using
"mapping best practices"
ie
http://proceedings.esri.com/library/userconf/fed16/papers/fed_86.pdf
although for some reason it is not loading
but chuck 'esri' onto the end
Best practices for using layers in maps—ArcGIS Online Help | ArcGIS
https://www.esri.com/content/dam/esrisites/en-us/media/pdf/architecting-the-arcgis-platform.pdf
and loads more.
Switch up to
'digitizing best practices'
'databases best practices'
You get the drift.... hopefully something will jive with your workflow
Thanks, I was able to open the proceedings from ESRI and it takes some time to open it and it works.
