Once, the relashionship is set.How can I test it make sure it works?How do I find RelationshipID?Thanks,Janusz
You need to add the tables/feature classes the relationships are based on to your map before publishing it..
What should I do to set Relationship ID?When I look through Services Directory rest point at may mapservice I do not see Relationshps: at all.
From 10 onward, it also provides information regarding the relationship of this layer / table with other layers / tables in the map service. A property to indicate whether the layer / table has attachments or not was also added at 10.
FeatureLayer l = new FeatureLayer() { Url = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSPetro/MapServer/0" }; l.Initialized += (s, e) => { int relationshipId = -1; foreach (var relationship in l.LayerInfo.Relationships) { relationshipId = relationship.RelatedTableId; break; } }; l.Initialize();
