The code sample below shows how one can add a map service to ArcMap using the GxCatalog dialog.
using System; using System.Collections.Generic; using System.Text; using System.IO; using ESRI.ArcGIS.ArcMapUI; using ESRI.ArcGIS.CatalogUI; using ESRI.ArcGIS.Catalog; using ESRI.ArcGIS.Carto; using ESRI.ArcGIS.Geodatabase; using System.Windows.Forms; using ESRI.ArcGIS.GISClient; using ESRI.ArcGIS.esriSystem; namespace GxDialog_Select_MapService_Layer { public class GxDialog_Select_MapService_Layer : ESRI.ArcGIS.Desktop.AddIns.Button { public GxDialog_Select_MapService_Layer() { } protected override void OnClick() { IMxDocument pmxdoc = (IMxDocument)ArcMap.Application.Document; IMap pmap = pmxdoc.FocusMap; IGxDialog pGxDialog = new GxDialog(); pGxDialog.Title = "Browse Data"; //pGxDialog.set_StartingLocation("C:\\Temp"); pGxDialog.set_StartingLocation("GIS Servers"); IEnumGxObject pEnumGx; if (!pGxDialog.DoModalOpen(0, out pEnumGx)) return; // Exit if user presses Cancel IGxObject pgxobject = pEnumGx.Next(); IGxAGSObject gxAGSObject = pgxobject as IGxAGSObject; IAGSServerObjectName agsServerObjectName = gxAGSObject.AGSServerObjectName; IAGSServerConnectionName agsServerConnectionName = agsServerObjectName.AGSServerConnectionName; IPropertySet propertySet = agsServerConnectionName.ConnectionProperties; //create a new ArcGIS Server connection factory IAGSServerConnectionFactory2 agsServerConnectionFactory2 = (IAGSServerConnectionFactory2)new AGSServerConnectionFactory(); IAGSServerConnection agsServerConnection = agsServerConnectionFactory2.Open(propertySet, 0); //get an enum of all server object names (services) from the server IAGSEnumServerObjectName soNames = agsServerConnection.ServerObjectNames; IAGSServerObjectName3 soName = (IAGSServerObjectName3)soNames.Next(); ILayerFactory msLayerFactory = new MapServerLayerFactory(); IEnumLayer enumLyrs = msLayerFactory.Create(soName); IMapServerLayer mapServerLayer = (IMapServerLayer)enumLyrs.Next(); pmap.AddLayer(( ILayer)mapServerLayer); ArcMap.Application.CurrentTool = null; } } }
