Hi,I have not used ArcMap for 2 months and suddenly it behaves strange: When starting a new map from scratch, I cannot add a basemap and I cannot create new (basemap or group) layers. I see the option and can click it and there is not even an error message, its just: nothing happens.Even when adding a basemap, I see the selection window and can select, for example, OSM. But nothing happens after that, the program doesn't even crash...Any ideas?I am using ArcMap 10.0thanks in advance, I could not find anything like this using search.Ben
I'm having the same problem, though I expect for a different reason. I'm working my way through learning ArcGIS and probably have done some things in a not correctl way. Here's a clip of my ToC for this map. I want to group symbol layers by trip [GWTrip1-Point, GWTrip1-Line]. When I try any of the methods described in the ArcGIS help file under "Working with group layers", none work. No messages are returned, no actions appear to be taken. I would be very grateful to know what I'm doing wrong and how to fix it.
Thank you very much ...
