var fieldsToDisplay = new List<string>() {"fieldName1", fieldName2"}; var attributesToDisplay = new Dictionary<string, object>(); foreach(var item in selectedFeature.Attributes) if(fieldsToDisplay.Contains(item.Key)) attributesToDisplay[item.Key]= item.Value; IdentifyDetailsDataGrid.ItemsSource = attributesToDisplay;
public void ShowFeatures(List<IdentifyResult> results) { _dataItems = new List<DataItem>(); if (results != null && results.Count > 0) { foreach (IdentifyResult result in results) { Graphic feature = result.Feature; string title = result.Value.ToString() + " (" + result.LayerName + ")"; _dataItems.Add(new DataItem() { Title = title, Data = feature.Attributes }); var fieldsToDisplay = new List<string>() { "School Name", "Address", "Zip", "Phone", "Website", "School District" }; var attributesToDisplay = new Dictionary<string, object>(); foreach (var item in feature.Attributes) if (fieldsToDisplay.Contains(item.Key)) attributesToDisplay[item.Key] = item.Value; if (result.LayerId == 4) IdentifyDetailsDataGrid.ItemsSource = attributesToDisplay; if (result.LayerId == 9) IdentifyDetailsDataGrid2.ItemsSource = attributesToDisplay; if (result.LayerId == 14) IdentifyDetailsDataGrid3.ItemsSource = attributesToDisplay; } //IdentifyComboBox.SelectedIndex = 0; }
Never mind, I got it with the following code: public void ShowFeatures(List<IdentifyResult> results) { _dataItems = new List<DataItem>(); if (results != null && results.Count > 0) { foreach (IdentifyResult result in results) { Graphic feature = result.Feature; string title = result.Value.ToString() + " (" + result.LayerName + ")"; _dataItems.Add(new DataItem() { Title = title, Data = feature.Attributes }); var fieldsToDisplay = new List<string>() { "School Name", "Address", "Zip", "Phone", "Website", "School District" }; var attributesToDisplay = new Dictionary<string, object>(); foreach (var item in feature.Attributes) if (fieldsToDisplay.Contains(item.Key)) attributesToDisplay[item.Key] = item.Value; if (result.LayerId == 4) IdentifyDetailsDataGrid.ItemsSource = feature.Attributes; IdentifyDetailsDataGrid.ItemsSource = attributesToDisplay; if (result.LayerId == 9) IdentifyDetailsDataGrid2.ItemsSource = feature.Attributes; IdentifyDetailsDataGrid2.ItemsSource = attributesToDisplay; if (result.LayerId == 14) IdentifyDetailsDataGrid3.ItemsSource = feature.Attributes; IdentifyDetailsDataGrid3.ItemsSource = attributesToDisplay; }Now all I need it to set the field attribute of "Website" to be a hyperlink in all three data grids.
public void ShowFeatures(List<IdentifyResult> results) { _dataItems = new List<DataItem>(); if (results != null && results.Count > 0) { //IdentifyComboBox.Items.Clear(); foreach (IdentifyResult result in results) { var temp = new Dictionary<string, object>(); var fields = new List<string>() { "School Name", "Address", "Zip", "Phone", "Website", "School District" }; //fields to display foreach (var item in feature.Attributes) { if (fields.Contains(item.Key)) temp[item.Key] = item.Value; } Graphic feature = result.Feature; string title = result.Value.ToString() + " (" + result.LayerName + ")"; _dataItems.Add(new DataItem() { Title = title, Data = temp }); //IdentifyComboBox.Items.Add(title); if (result.LayerId == 4) IdentifyDetailsDataGrid.ItemsSource = feature.Attributes; if (result.LayerId == 9) IdentifyDetailsDataGrid2.ItemsSource = feature.Attributes; if (result.LayerId == 14) IdentifyDetailsDataGrid3.ItemsSource = feature.Attributes; }
public void ShowFeatures(List<IdentifyResult> results) { _dataItems = new List<DataItem>(); if (results != null && results.Count > 0) { //IdentifyComboBox.Items.Clear(); foreach (IdentifyResult result in results) { Graphic feature = result.Feature; var temp = new Dictionary<string, object>(); var fields = new List<string>() { "School Name", "Address", "Zip", "Phone", "Website", "School District" }; //fields to display foreach (var item in feature.Attributes) { if (fields.Contains(item.Key)) temp[item.Key] = item.Value; } string title = result.Value.ToString() + " (" + result.LayerName + ")"; _dataItems.Add(new DataItem() { Title = title, Data = temp }); //IdentifyComboBox.Items.Add(title); if (result.LayerId == 4) IdentifyDetailsDataGrid.ItemsSource = feature.Attributes; if (result.LayerId == 9) IdentifyDetailsDataGrid2.ItemsSource = feature.Attributes; if (result.LayerId == 14) IdentifyDetailsDataGrid3.ItemsSource = feature.Attributes; }
public void ShowFeatures(List<IdentifyResult> results) { _dataItems = new List<DataItem>(); if (results != null && results.Count > 0) { //IdentifyComboBox.Items.Clear(); foreach (IdentifyResult result in results) { Graphic feature = result.Feature; string title = result.Value.ToString() + " (" + result.LayerName + ")"; _dataItems.Add(new DataItem() { var temp = new Dictionary<string, object>(); var fields = new List<string>() { "School Name", "Address", "Zip", "Phone", "Website", "School District" }; //fields to display foreach (var item in feature.Attributes) { if (fields.Contains(item.Key)) temp[item.Key] = item.Value; } Title = title, Data = temp }); //IdentifyComboBox.Items.Add(title); if (result.LayerId == 4) IdentifyDetailsDataGrid.ItemsSource = feature.Attributes; if (result.LayerId == 9) IdentifyDetailsDataGrid2.ItemsSource = feature.Attributes; if (result.LayerId == 14) IdentifyDetailsDataGrid3.ItemsSource = feature.Attributes; } //IdentifyComboBox.SelectedIndex = 0; } }
This is a question for REST API. I believe this is new to 10.1, in "dynamicLayers", you can specify "fields". In pre-10, you will get all fields but your Silverlight application can only show a subset of them. You can modify the following SDK sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#IdentifyInstead of this line: Data = feature.Attributes You can create temporary variable that will hold attributesvar temp = new Dictionary<string, object>(); var fields = new List<string>() {"field1", "field2"}; //fields to display foreach(var item in feature.Attributes) { if(fields.Contains(item.Key)) temp[item.Key] = item.Value; } //more code goes here Data = temp
