Hi,My scenario is, I have several mxds with the same layers, different layouts, used for map templates. I updated the symbology and labeling details for a layer in one mxd and want to push it into the others.Attempting the following workflow results in an AssertionError during arcpy.mapping.UpdateLayer()1. save the new details as a layer file.2. run this code
files = r'C:\Temp\Layouts'
newLyr = arcpy.mapping.Layer('H:\\GIS_LayerFiles\\WaterNetwork\\Hydrant.lyr')
layerLongName = 'Water Network\\Hydrant'
symbologyOnly = False
for r,d,f in os.walk(files):
for fl in f:
path = r+'\\' + fl
if fl[-3:] =='mxd':
print path
mxd = arcpy.mapping.MapDocument(path)
df = arcpy.mapping.ListDataFrames(mxd)
layers = arcpy.mapping.ListLayers(mxd)
for lyr in layers:
if str(lyr.longName).startswith(layerLongName):
arcpy.mapping.UpdateLayer(df,lyr, newLyr, symbologyOnly)
print lyr.longName + " symbology updated."
I get the following errorTraceback (most recent call last): File "<interactive input>", line 1, in <module> File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\utils.py", line 181, in fn_ return fn(*args, **kw) File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\mapping.py", line 1477, in UpdateLayer assert isinstance(data_frame, DataFrame)AssertionErrorSymbology only works fine, but as mentioned I have labeling changes I want to include.I'd much rather not update them all manually.
