(the script was straight from the ESRI python tutorial)>>> #Buffer the roads feature class for each distance in the distance list ... import arcpy ... arcpy.env.workspace = r"C:\PETER PENG\ppTests.gdb" ... fc = "TestApr17" ... distanceList= ["100 meters", "200 meters", "400 meters"] ... #loop thru ea distance in the distanceList ... for dist in distanceList: ... outName = fc+"_"+dist ... arcpy.Buffer_analysis(fc, outName, dist) ... print "Finished buffering" ... Runtime error <class 'arcgisscripting.ExecuteError'>: ERROR 000210: Cannot create output C:\PETER PENG\ppTests.gdb\TestApr17_100 meters Failed to execute (Buffer). >>>
- Tried the non-python method: Buffer tool in toolbox, worked!- Tried different file path names, taking away "_". Does Python not accept " "(space)? I thought raw data was fine?- Message Log attached- Have no idea how to get this simple script to work, any help appreciated!
