We've created an Interactive Map application which runs fine under socket 6080 but when we attempt to move it behind a Reverse Proxy Server, some features/layers cannot be added to the map. I've replicated the error on my test server by adding socket 6443 to the IIS site instance. Some Resources are added while some are not. Any thoughts?
Mark
If you use the Chrome dev tools when loading the application, do you see any requests that fail? If you look at the response under the Network tab, you should be able to determine why the layer fails to load. It could be a permission issue or the service was deleted.
