Thank you Nimesh for your Guidance..I have installed the IOS and ArCGIs SDK and Wheni Click on the Sample.XcodeProj it opens up in Xcode And When I Hiit Run..It threw an error "Lexical or Preprocessor issue UIKIt/UIkit.h not found"..Do you have any idea on this issue..thanks
- (BOOL)mapView:(AGSMapView *)mapView shouldShowCalloutForGraphic:(AGSGraphic *)graphic { //self.mapView.callout.accessoryButtonHidden = (graphic.layer == self.inspectionLayer); return YES; }
Is there any documentation on the "Offline Inspections Sample - UC 2011 Plenary Demo" sample?I have downloaded and configured successfully, but only get so far as being able to click on the green sticky note to "Make sure data is downloaded before going into field" and then clicking on the "Start Inspections" yellow sticky note.That loads some points on the map, but then I do not see anything else happening, and no other buttons to click, etc...Is there a video showing this app working or some documentation to assist with getting working and loading my own data into the app?
