Hi
In CityEngine Scene Layers my layers are on the correct order, but when are exported to Webscene CityEngine put the layers randomly. There´s a mix of Static Models, Basemap, Shapes....
Maybe is a basic question but I don know how to fix it.
That's strange. I can't seem to reproduce it. The layers are all in the correct order if I follow the steps to export the scene in Tutorial 15 (Help -> Download Tutorials and Examples). Does this tutorial work for you?
Tutorial 15: Publish web scenes—CityEngine Tutorials | ArcGIS Desktop
I noticed that there's an asterix in the Scene tab which means that the scene has not been saved. Does saving the scene help? The exporter should export the scene with the changes even if the scene is not saved, but it would be interesting to know if this helps or not.
Hi Cheryl
I know it´s tottaly weird.
The scene was saved before export, but still doing the same . Check the prints, please. I´m not using any previous export Settings. 😞
Did Tutorial 15 work for you?
I noticed you are using version 2015.2. You could try upgrading to 2016.1, but I don't think it should make a difference in this case since exporting Tutorial 15 with 2015.2 also worked for me.
I did the Tutorial 15 and worked very well.
Crazy isn´t?
